She drove home.....and flawlessly. I'm stunned how well it drives! It was a 2.2 T3 that was replaced with a 2.5 T1 with the T3's wiring harness and converted to a T2 running 15 PSI of boost making almost exactly the same amount of horsepower as the original T3 but at 2k RPM instead of 3.5K.... What a beautiful bastard car! I can't tell you how happy that makes me.
It was kind of weird, though. The very first time we started it, idle was incredibly smooth. (Yes, I still have the balance shafts hooked up.) I pulled it out of the garage, and it created a huge pillar of gray smoke, clearly running rich. I drove around the block and left a beautiful trail of smoke behind me. Couldn't figure it out, so I swapped it back from the FWD stage 3 back to the stock SBEC-1, and the smoke was vastly reduced, but now it was painfully obviously blue.....
I popped the oil cap off, and...no blowby! I thought, "Bad turbo seals?" I drove around the block again, and it was stalling and bucking and whatnot. I limped it to the parking space and FINALLY it threw a power loss code! 13! Sure enough, the crossover from the MAP to the BAR sensor was rotten. Swapped it out, and TADA!! no smoke, perfect driving, total awesomesauce.
So, my biggest question is, "Where did the blue smoke come from?" I mean, there was no mistaking the smell or the color. And it ran for quite a while until the moment I fixed the MAP readings.
Whatever, don't care, haha! It still does some weird stuff. The Air Bag light is on, the front right turn signal doesn't light, the front left side marker doesn't light, one of the backup lights doesn't light, the speedometer reads about 15% higher....some wiring is weird, I'm sure.
Anyway, it drove home! And like I said before, flawlessly. (= Boy does the front-end on the Spirit hook hard! I don't know if the differential is different, but it definitely feels better than the Shadow. I spun a tire in 4th several times and even once in 5th, but the Spirit simply flies forward like one of those magnet-driven roller coasters.
