if you're doing a 2.2 t2 conversion to 2.5 you can run the LM with no changes, but your fuel injectors will be almost maxed out. Turn down the ignition timing to about 8 as the 2.2 has a much more agressive spark curve than the 2.5 and you may get some detonation if you don't turn the timing down.
