1989 dodge daytona es turbo
Hi, I was wondering if anyone had a 91 engine wiring harness. I'm swapping a 91 v6 with an 89 2.5 turbo. I don't think the 89 harness will hook up. I think I have a computer for a 91. Also if anyone wants the v6, automatic transmission and wiring harness make me an offer. Thanks
here's all the 91 wiring harnesses for it
1 04625246 1 WIRING, ENGINE, 2.5 TBI
05267236 1 2.2 Turbo
04625247 1 2.5 Turbo
04625249 1 3.0 Turbo
04481301 1 WIRING, Fuel Rail, 2.5 Turbo 1 (Use Insul. 4419499)
04481505 1 2.2 Turbo 4
04625344 1 WIRING, Throttle Body, 2.5
04625255 1 WIRING, 3.0 Eng., w/A-604 Trans.
2 WIRING, FRONT END, Headlamp to Dash Panel V24
04625230 1 2.5 Eng. TBI, 5-Spd., A-413 Trans.
04625232 1 2.5 Eng., w/Anti-Lock, w/o EVIC, w/5-Speed & A-413
04625233 1 2.2-2.5 Eng., 5 Spd., A-413 Trans., Turbo, w/o Anti-Lock Brakes
04625236 1 3.0 Eng., 5-Speed, w/A-604, w/o Anti-Lock or EVIC
04625231 1 2.5 Eng Non Turbo, Exc. ABS & EVIC - CANADA
04625234 1 2.5 Eng Turbo Exc. ABS & EVIC - CANADA
04625237 1 3.0L Eng Exc. ABS & EVIC - CANADA
3 WIRING, Battery
04625251 1 Positive, Man. Trans. 2.2, 2.5 Eng.
04625250 1 Positive, w/A-413 Trans., 2.2, 2.5 Eng.
04625253 1 Positive, 3.0 Eng., Man. Trans.
04625252 1 Positive, 3.0 Eng., A-604 Trans.
4 04304678 1 CABLE, Battery & Engine Ground (Repair)
5 05233396 1 SWITCH AND SENDING UNIT, Oil, Turbo
05227050 1 2.5, 3.0 Eng., (Use Insul. 4439081)
6 1 SWITCH, Oil Pressure
7 04483407 1 FITTING, Oil Pressure (Export)
8 04504203 1 SENDING UNIT, Eng. Temp. Gauge
04437313 1 SENSOR, Eng. Temp.
Based on that I think I need
04625247 engine wiring
