1 - 6 of 6 Posts
I’m wondering if anyone knows of a good TD mechanic in the Western Pennsylvania area (around Pittsburgh). I plan to do and have done some basic maintenance on my ’89 LeBaron GTC convertible Turbo II with 5-speed, but I would like to find a mechanic in this area that understands these cars, knows what needs to be done (and doesn't) and can get the most out of them. I would like to keep my car for the long-haul, so everything doesn’t need to be done right away. I just want to make sure I know a mechanic is targeting the right things to make it run as it should, considering it’s a 30-year-old car. Any help would be much appreciated.
Discussion Starter #2
Thought I'd ask this again. Anyone have any thoughts about a turbo Mopar mechanic in the Pittsburgh area? I thought I found someone, but while their skills were fine, dependability & communication were/are awful. Need to try to find someone else, preferably in the northern suburbs of Pittsburgh. Anyone? Thanks!
I do not know anybody, try posting in the "Regional Forums".
You will probably need to locate an old Mopar Tech but they are probably all retired like me.
Do you have questions/concerns or is there anything you need assistance with at this moment that we may be able to help with?
Thanks for the offer! I have never really been a DIY mechanic, and I really want to have someone to take the car to for the big stuff. Right now, I need to have the turbo lines replaced. I managed to get the coolant leak stopped and pick up new lines from TU, but I need someone knowledgeable to put them on. Someone who has done it before would know the best way to access the connections (likely with the car on a lift) without taking half the engine apart. When I was stranded by the roadside, it would be nice to have had a place to tow it to. That's what I'm looking for.
Thanks! As you can see from my original post, I have been searching for a long time with almost no luck. So, I could use a little of that!!!
1 - 6 of 6 Posts
