Had to rebuild the entire front end of a Neon SRT4. It had been restored (if you can call it that) to a point where everything was hammered and tied back. hidden under a new bumper cover. They directly drilled self tapping screws through the new headlights into the radiator support. So the lights shined wherever and were not safe. In fact the whole front was not safe. Luckily the frame is intact. But I have ripped the whole thing off and replaced it only to get to a point to where i do not have the mounting hardware for the inter-cooler nor the headlights. Im sure i will run into more as i go. I mean this car was so bad that the motor mounts were snapped. Previous owner needed a new exhaust. Instead of replacing the inexpensive motor mounts to get the exhaust to line up, he had it cut and poorly welded into place. So now I have to rip the exhaust off just to get the motor mounts in. and then have it cut and replaced again. Keep in mind this idiot said he was a mechanic.
SO FRUSTRATED!!!! Anyway. Any help or advice would be greatly appreciated.
Thank you
Thank you
