1 - 12 of 12 Posts
I have a 1991 Spirit RT I am working on. Trying to bring it back from the dead, it has been sitting for years. I am having trouble locating a replacement timing belt tensioner and idler, from my research I think the part numbers are 4484464 and 4484465 and discontinued. Anyone have a substitute part number? Thanks!
The orange is the intermediate shaft. It drives the distributor and oil pump.
The blue is the tensioner. It has an eccentric bolt hole. You turn the 1 1/8 in (i think) bolt to tension the belt then, tighten the smaller bolt.
Also while you are in there you should do the seals on the 3 shafts.
Discussion Starter · #7 ·
There is 2 cam gears, crank, intermediate shaft, tensioner, idler. I found a tensioner, but no idler pulley.
FWD performance sells nice aftermarket tensioner, and this idler works perfect with a few washers behind it.
Subaru Impreza 2.5L Engine Timing Belt Roller Koyo 13073AA142
1 - 12 of 12 Posts
