1 - 10 of 10 Posts
LOTUS/CHRYSLER Turbo III Rocker Assemblies?
Are these the rocker assemblies from the Lotus?Chrysler Turbo III engine?​
I have 8 of them. I think one is missing the tappet. Need to look again to confirm.
They have low miles and have been sitting in a old metal ice cube tray with oil in it. That's why they look so good. I wiped off the oil on the one pictured for better viewing.
46910 casting # is for 1991-93 T3 engine
part numbers in the part books:
4484379 L rocker arm
4484380 R rocker arm
1 ARM, Rocker Assembly
4484 380 8 Right
4484 379 8 Left
2 4484 418 16 BOLT, Rocker Shaft Retaining
3 6101 461 16 WASHER, Plain M8
4 RETAINER, Rocker Shaft
4424 007 16 Intake and Exhaust Shafts
4484 423 1 Exhaust Shaft End
4424 008 1 Intake Shaft End
5 4442 045 2 KEY, Camshaft Sprocket
6 4484 419 1 SHAFT ASSEMBLY, Exhaust Valve Rocker
7 4484 373 1 SHAFT ASSEMBLY, Intake Valve Rocker
8 4442 941 1 CAMSHAFT ASSEMBLY, Exhaust ***
9 4442 940 1 CAMSHAFT ASSEMBLY, Intake ***
10 4424 061 1 SPACER, Intake Rocker Shaft
11 4424 035 16 LOCK, Intake Valve Spring Retainer
12 4424 034 16 LOCK, Exhaust Valve Spring Retainer
13 4638 413 1 SEAL PACKAGE, Valve Stem ***
14 4424 033 16 RETAINER, Valve Spring
15 4442 213 16 SPRING, Valve
16 4484 407 16 SEAT, Valve Spring
17 GUIDE, Valve
4484 408 16 Standard
4484 429 16 Oversized
18 4484 422 8 VALVE, Exhaust
19 4484 421 8 VALVE, Intake
Thanks Marty,
Its been a few years since I've been in a Mopar parts manual.
How do you like Arizona? I'm doing everything I can to get out of Illinois.
Discussion Starter · #6 ·
Were these rockers sold? Are any available anywhere?
I still have the ones mentioned above. However, I just moved and they are in a storage container somewhere. I can look for them if your interested.
Sure. How many do you have? Both LH and RHand? But should I not get new rollers for a new cam? Or is it ok to put used rocker arm rollers on a new cam?
Discussion Starter · #8 ·
Judging from the LH on the pictured part, I'm going to say they are all Left Hand.
As for rollers on a new cam, I would ask an engine builder.
1 - 10 of 10 Posts
