61 - 68 of 68 Posts
Discussion Starter #62
Should be the same between DOHC and SOHC.
The T3 16 Valve head is way different from the 8 Valve head shown.
You have to pull the rail the lifters are attached to to perform. If you use the Mercedes Benz lifters you HAVE to buy the disks for the Mercedes Benz lifters.
HELLO..
Every one,,been away from site and my R/T for awhile.
Can the lifters be changed out WITH OUT removing the cams??
And if so is there a video some wheres showing this??
Mike In Maine
On the 16V, just unbolt the rocker arm assembly, and change out the lifters. No numbering needed, the rockers stay attached to the shaft. Cam is bolted in separately. Loosening the rocker arms is actually part of procedure to setting timing belt tension to take the load off the cams.
do any of you guys know where to have camshafts made? had a rocker remove 1/4 inch of one of the lobes or replacement cam shafts thanks Dan
thanks INSATINSSEAT your awesome had a coustomers car down 17 months now because machine shop jacked me around about cams! Dan
61 - 68 of 68 Posts
