1 - 20 of 22 Posts
Hey guys,
Im beginning to become frustrated with the lack of aftermarket parts available for my daytona and was thinking about moving on to another car. I have been looking to lower my daytona to give it a bit of a new look but cannot seem to come up with a good way to do it, besides cutting springs or the rather expensive eibach kits, or seen many with it done. If anyone does have their daytona lowered, I would love to see some pictures of it as well as know how they went about doing it.
Clearly you have a car that does not suit your needs, drive it out here and leave it with me and I'll pay for your plane ticket back home, especially if it's blue.
how low do ya wanna go ?
my 86 turbo z sitts about 1 inch lower than my 87 shelby z
should be the same with regards to your 89 - I know they're not the lowest , a buddy had an 89 shelby new and I thought it sat kinda high
try compareing your car to the first gen turbo z - if the turbo z is low enough swap in a set of those springs - should be pretty cheep
remember a daytona turbo vs a turbo z are two diff cars and the turbo z should be lower
interesting as i will lower my daytona as well, so if a 84-6 Z is lower than my 92 i might grab a set from those years daytona
eyeball it first
I put the good struts and springs from my 87 z into the blue car below and the front end went up
then I noticed the back of my 87 was higher than the 86 too
you can see a little diff from front to back in the pic
it has 215 60 15's on all corners
will have to do that,
as i dont really know if i want to pay out $300 for a set of eibach's from forward motion
should only make about an inch of diff
with the changes to the a arms and the front of the front wheel well opening the 215 60 15's should fit better on the 92's
but I haven't test fitted them on mine yet
i haven't figured out what size tires i am going with yet, right know i have a set of 17" rims on there but they are one size larger than stock and they rub a bit, might just go with a set of 16" pumpers
Neon struts and springs up front, 1 cut coil on back. Sits about as low as it will go before affecting ride and steering
will first gen neon struts and springs be a direct bolt on, if so i can just grab a set of coilovers for my daytona
Discussion Starter #12
naw that would be just too easy ...
How much modding does it take? Or would I be better off just going with the turbo z shocks? I would like to just cut my springs but I dont have a spring compressor and all the shops in my area have laughed at me so far when I asked if they can cut a coil off my springs.
sorry I was being sarcastic
I honestly don't know what you have to do to use the neon coil overs
you could get a spring compressor from a partssupplier that does loan a tool or from some tool rental shop
then you could do it yourself
- and laugh at them 'cause they ain't makin your money today
That actually is informative and brings up ideas about new possibilities but this is for an L body, later in the thread it says it will not work on the daytona which is what I have
You can use the Neon struts on the Daytona, but you have to modify the upper mounting point. The struts do bolt up to the knuckle with no problems. I guess it depends on how much you want to modify your strut towers.
1 - 20 of 22 Posts
