1 - 6 of 6 Posts
Will the Neon Quaife will fit into an A413? I understand that OBX is gonna be making an LSD similar to the Quaife. I found this info over on the Neon.Org Forums. Anyone else hear about this? Thanks.
Christian J. Grest
I believe so, I was under the impression that all you need is to make a spacer to move the ring gear out a bit, and clearance the case a little. There was a post about all of this a few weeks ago.
Jeff
Jeff
Right... Spacer, clearance the case and clearance the diff cover.
1 - 6 of 6 Posts
