This is a parts list, they make the 2 lines and sell the parts and ship the parts. You can order them based off my invoice number as well or just write down the part numbers. I did however add one cheap fitting for a carb in there though lol. This is for people with a Garret turbo. Has the silicone lines for the return sides and SS steel for the feed sides. 4 protected clamps and one plug for the origanal oil feed hole. The photo shows how they go together. I didn't show the mitsu lines, which are the same except for the coolent fitting on the turbo. But if your going this far I would assume your at least running a Garret... Spokanehose.com is where I get all the pieces
what do you mean by oil feed plug, this is probably a noob question LOL
where the factory line comes out then is a weldment or fitting on the oil block, this plugs that. People that make SS lines drill and tap this plug for the oil feed. I don't bother with that I just plug it off and use another hole in the oil block:thumb:
hell for this price i am hooked on it, i will order from them
