I have purchased a MAP bleed to be installed on my 84 T1. I plan on installing it in the vacuum line after it splits off into 2 lines. One of the lines goes to the fuel pressure regulator and the other goes to the firewall. Is it ok to put it after the split but before the line goes through the firewall to the sensor. Also, how many turns does it take to see a difference.
