I have access to a Maserati DOHC engine and transmission including the wiring harness for a relatively cheap price. The problem is the engine had an oil pump failure and seized up. The cylinders do not have any scoring so it may actually be a rod bearing that seized up. I am seriously considering getting this engine and rebuilding it for my 85XE laser. I am wondering if it is possible to get replacement parts for these engines. Do they use the same rings as a standard 2.2 engine? Also I would not be able to get a Maserati gear shift and cables and I assume my 525 shifter and cables would not work with the Maserati transmission. I will not be using my car for racing but it would be nice to get a little more power than the T1 draw through allows. Has anyone here had any experience with a Maserati engine swap? What kind of expenses should I expect for such a project? I found a write up on the TC at this website: Chrysler's TC by Maserati cars at the bottom of the article it mentions difficulty in finding replacement bearings.
