the rear disc brake cars will have a master cylinder with a bigger bore and piston inside
the resivor on top will also be bigger
you can put it on the 86 disc/drum car for better brakeing effect
if you look at the master cyl , on top of the front end , just below the res you will see a number cast into the part
this denotes the piston/bore size
