1 - 1 of 1 Posts
I put together a hybrid a555 with a maximizer t350 lsd Maximizer Performance LSD Fits 1994-98 Neon / 1995-99 Eclipse Non-Turbo 420A | eBay
It is way too tight, it skids the tires when turning, it also came put together backwards on the inside. But maybe during the reassembly when I had to cross torque the bolts on a few threads at a time for a half hour I screwed something up. Hard to say if it's worth it, if the tightness destroys my axles or anything else, like my steering system which is taking more abuse compared to the open diff (more steering effort than before) then I'll get the modern performance LSD or go open. I did hone the axle contact surface that isn't the splines. Also neglected to check input shaft play when I put the trans together, and I think it's too loose since if I don't slowly let the clutch out in neutral it will make a horrible rattle noise, I pulled out the guts in car and found nothing wrong.
1 - 1 of 1 Posts
