Whats a good setup for my mini? I know alot of guys use the NPR's, but I wanna keep my a/c. I wa gonna try and rig up a stocker off an '88 Z. any suggestions? Pics would probably help too.
thats what I ran on my mini I just moved the rad over with a fabbed bottom bracket(just enough to mount the intercooler) and drilled new holes in the upper core support and then flipped and cut the upper rad hose using a piece of pipe clamped inside to reconnect the hose and shortened and spliced the lower hose similar to the upper sorry I am not photo capable just take your time it will be obvious as you go. ps pull your grill off to work easier good luck.
