My 2005 minivan died, so I decided to convert an 89 v6 grand caravan (actually plymouth) to 4cyl, turbo, 5 speed. Cleaned up an old 2.5 and got a modified 523 from my son along with parts of a 90 harness. Had to make up the missing parts of the harness from old harnesses. Anyway, it runs well now.
Thought I might share my experience with the air to water intercooler installation. Came out very clean.
The original radiator fan had a long motor that interfered with the desired location to the air to water intercooler. So I went to the junkyard and picked up a Volvo brushless PWM controlled fan. Fits perfectly as you can see in the picture and the shroud is a big improvement over the original.
This fan is controlled by PWM, so I have a small PWM generator that is tuned on by the wire that used toground the fan relay coil. The SBEC grounds this wire when it wants to turn the fan on.
I'm going to relocate this module in the cabin, but it works great. The fan is very powerful and doesn't need to run at full tilt. I have it running at 50%.
Here's how it's wired:
I bought a brand new honda radiator. They are all aluminum, brand new, and dirt cheap on ebay. Modified it and fit it in front of the stock radiator. The honda radiator works as the cooler for the Air to Water setup.
