Hi to all, this is probably going to seem like a stupid question but here we go. How much shaft play can you have on a mitsu turbo. When I reach inside the inlet housing I can move the shaft around a little. If I gently grasp the shaft with needle nose pliers, the play seems even worse. The thing seemed quiet and seemed to boost ok before I tore it apart. The reason I ask is I just got laid off from my job and Im pinching every penny I can putting this thing back together. I do have garrett t1 log turbo I could use, but would have to make the required mods to put it on there and Im not to sure if its in any better shape. Any insight would be appreciated.
