Here are a few pictures of the repainted modesty cover, the AIRAID, and the new battery cover. Have to get the loomz yet & paint the battery cover, fluid lids, and the intake lines. (and YES...clean the engine x( )
NSCR FAN...Yes, little by little. It got up to 58º here today & so I HAD to take advantage of doing as much as I could with the little time I had today.
363...Yes, I want to, the only problem is that the battery cover is VERY texturized. I will need to do a lot of sanding to get it smooth enough for the mirage paint. It might be one of those "I have to be in the mood" projects.
Thanks everyone!! 363...Yes, I want to, the only problem is that the battery cover is VERY texturized. I will need to do a lot of sanding to get it smooth enough for the mirage paint. It might be one of those "I have to be in the mood" projects.
Actually what happened was when I was pulling off the paper backing, I had the sheet sitting on the porch, the wind kicked up & blew some small rocks/dirt from our "GRRRRRavel" driveway & so there are little bitty bumps under it. I will replace them in the spring.
Kat that where I got my battery cover and has you can see in the photo I painted mine. I took some wet & dry sandpaper and sanded it really good (just enough to knock off the shine). painted it with primer. then the blue color and a few coats of clear cote
I saw the two different colors of the paint. I am undecided what color I want to go with. Yours looks awesome. Is that the Magneta to Gold? Is that the same color you used the first time?
Hi
I know its a long shot
im looking for a JL Audio Stealthbox subwoofer box or any other subwoofer box that fit in the side panel
Would you still have one?
[email protected]
7808195657
I've taken an interest in adding old original Chrysler goodies to my Cruiser. So far, I've managed to procure a 1948 Chrysler chrome emblem which is on the lower section of the front grille. I also have the 1949 Chrysler script wheel covers.
Is anyone else doing anything like this, or is this...
Finally managed to find Tennessee's State Laws on Vehicle Lighting. It's under Title 55, chaper 9.
I started by going to MetaCrawler and then plugged in "tennessee legislature" as a search.
That search's first result netted one entitled "Welcome to the Tennessee General Assembly" So I went...
Since I've gotten my PT, I've been looking at the Xenon Bruiser front bumper (suits my taste as opposed to some of the other options out there). Anyways I believe I measured front bumper clearance to be 7 " a while ago (when there was no snow on the ground). The specs for this bumper with...
