All New Parts unless otherwise indicated;
Verify parts will fit your specific application based on the part numbers I've provided.
Discount for multiple purchases :)
Prices do not include shipping.
Sealed Power E-453K Piston Ring set, Standard Size, all 2.2 & 2.5 Turbo '84-'93 $60
Clevite MS-1533P Main Bearing Set, standard size, fits all 2.2 & 2.5, '81-'95; $40
Poly Passenger Side Engine Mount '81-'89, see http://www.polybushings.com/pages/3565.html SOLD
Stock Style Passenger Side Engine Mount '81-'89, Filled with Liquid Nails, Lightly used, Free
Wagner R108168 Reman. Master Cylinder 'Large Bore', fits minivans,TDs w/ 11" front discs, or SLH upgrades $15
Moog K7147 Ball Joint, all '84-90 FWD $12
Fram FT1065 '83+ A413 (& 41TH) Filter Kit $6
(2) GKN - Beck/Arnley W72-094 rear wheel seals, solid discs '87-8 shelby Z, '87 shelby lancer, TC ; pending
Fel-Pro TCS 45495 camshaft/crankshaft front seal set, all 2.2 & 2.5, '81-'95; pending
(2 sets) Raybestos H5600-2 Caliper Bushings (2 each) fits oodles of TD front disc brakes $3 each
(4) EIS C7869 Front Disc Caliper Repair (Rebuild) kit ; same as RAYBESTOS WK1371 $1 each
Fel Pro ES 72143 Exhaust Flange Bolt & Spring Set, all 2.2 & 2.5 + oodles of other ChryCo products $2
Fram g7611 'flex fuel' fuel filter; nice SS construction, braided inlet line. pending
Auto Extra (Anchor) 2617 A413 trans mount '84+; filled with Liquid Nails, never used $3
Fel-Pro 60810 2.5" exhaust donut, fits all 2.5" TDs plus 3.0, 3.3, 3.8, neon, etc $4
Gates T153 'round tooth' Timing Belt '89-95, 2.2 & 2.5 pending
AUTOSPECIALTY/KELSEY-HAYES 2838103 disc brake pads, for '87-8 Shelby Z & '87 SL & TC rear solid discs (?) $7
Friction Master D220 , Front Disc brake pads '84-7 EEK 'small' (interchange w New Jersey American & FDP Brakes D220) $4
RAYBESTOS SGD219M Front Disc brake pads '84-90 EEK 'large' $4
FEL-PRO MS90947 Intake/Exhaust gasket set, all '81-95 2.2 & 2.5 $1
FEL-PRO BS401681 Front Crank Seal kit all 2.2, 2.5, 3.3, 3.8, 3.5 $2
Msg me yur email addy or cell # if you want pix.
Discussion Starter #2 (Edited)
more new stuff:
Standard Motor Product PR146 'One Piece Intake' Fuel Pressure Regulator $30
Moog National 3459 trans output (halfshaft) seal, MANY others $3
National 3638 Input Shaft Seal $3
Chicago Rawhide (same as SKF) 13953, early 2.2 camshaft seal pending
Timken 713655 '92-3 Dodge Truck Timing Cover seal $4
(2) Timken 5604 Wheel Seal, all '78-95 FWD $2
ACDELCO 46G0027A Sway Bar Link Kit, Neon + MANY others $4
Discussion Starter #3 (Edited)
More New Stuff:
Jegs 0555-41043 White Face 0-100psi liquid filled fuel pressure gauge SOLD
Jegs15270 Inline Fuel Pressure Fitting (for above gauge ;) ) SOLD
4 Seasons 85107 cast aluminum thermostat housing, all 2.2/2.5, could be polished or anodized $7
Drainage Industries 1-1/2" Full Flow Check Valve aka "D-Valve" $7
#4 Cylinder Mod Block-off Plate ONLY (no O-ring, bolts, fitting, etc.) $25
Used:
Defi D-Gauge DFO41 narrowband A/F gauge $15
Magnacore KV85 Competition (THE BEST!) 5-piece Spark Plug & Coil Wire set, all 2.2/2.5, like new, with barely noticeable tracking on couple of terminals, otherwise MINT SOLD
Genuine GM 16040749 3-Bar MAP sensor pending
