Just picked up an 88 Town and Country wagon in avg rough shape. It has multiple electrical problems. I was told it was just a door sensor since the pass door is dented pretty bad and sags. It kills the battery overnight if it's left plugged in and it came with 2 brand new batteries and a piece of paper with a electrical specialists number on it so I'm 100% sure it's not the door sensor. The red door warning was on but it was a back door not the damaged one and I fixed it with a piece of plastic (sensor was shorter than it should be) now there is no dome light or door warning light.
Problem 1 is the power draw I pulled fuses and it was still drawing power. It seems to come from this wire
Problem 2 is pretty low voltage. I pulled the stock Bosch alternator and the wire to the black module on the back had a broken contact inside the alternator (Not connected but it still passed?) and the bearing was noisy But we ran the autozone test it PASSED 14.5v and ripple was in spec and we ran the test 4 times....
Problem 3 is speedo acting weird but it smoothed out after a ride around town....
I put in a new alternator but the short seems to still be there (bright spark from neg terminal when hooking up). I never ran it since I was fixing the leaking trans hoses which turned to a 3 hour nightmare when I pulled the battery tray I saw a heater hose getting dug hard by a bolt protruding from the radiator and the heater valve snapped and all the hoses were rock hard trash so I ripped out all 4 hoses and the broken valve out. Tomorrow I'm getting the new valve and replacing all the hoses. I still don't know what is up with these electrical problems......
