Ok. Here's the deal:
I just changed My cam seals and Timing belt. Everything is great. Car has almost 20mm/hg of Vac. (was at 12 before I did the belt.) Timing is set at 12deg. at idle with cts unpluged.
On my way home the Disco A/f gauge is lighting up the last red and first yellow lights. And, for some reason, if I punch it It dies at 4000 rpm and at 4500 and at 5000 rpm. The condition resembles overboost shutdown. It also does this at Idle.
No pinging, or red turbo, just that odd miss. Pulls like a banshee till the "glitch" hits. Boost it set at 12 psi. All vac lines are good. I figure that because if I had a leak somwhere, the car wouldn't give me 20mm/hg.
Any Ideas?
Any Ideas?
