So here is the skinny. Negative battery terminal connector has a large wire and a small wire coming out of it where it connects to the battery. Where does the smaller wire run to? Its oxidized all the way thru and broke while the engine and tranny where being removed and re-installed.
I have included a crudly drawn picture due to not having a photo of the wire. If someone could tell me what it goes to I would greatly appreciate it. Photos would also be accepted :thumb:
below is a third graders rendering of what the wire in question looks like
note I made this in 30 seconds so give me a break lol.
Small ground wire should go to the body (fender) near the battery.
Good idea to check all the ground straps while you are fixing this one. Very ODD problems can creep up, all caused by bad grounds!
Law
R.I.P Dennis Jarvis
Katlaw is correct. My grounds were so bad I had to buy a groud wire kit from FWD.
Discussion Starter · #4 ·
sounds good. I was planning on replacing all of the grounds at some point but I suppose now is better than later. Thanks a bunch!
