1 - 13 of 13 Posts
I will make this a sticky once people know it is here.
I had this problem 10- 12 years ago and again this past week.
Problem;
CEL Illuminated With A Code 41 (Alternator Field Circuit Not Switching Properly)
Cause: (SEE PICTURE #1)
Worn Brushes Not Making Proper Contact With The Commutator
A New Brush Holder Can Be Purchased for Under $10.00 on eBay.
I Stock One.
Tools Needed:
1)1/4" Drive Ratchet
2)7 mm, 8 mm, 10 mm, 12 mm - 1/4" Drive Deep Sockets
3)#2 Stubby Phillips Screwdriver
4)Compressed Air (Can For Computers Will Work Fine)
5)CRC QD Electrical Contact Cleaner or 91% Rubbing Alcohol
6)Toothpick
Time Required;
1/2 - 3/4 Hour W/Alternator On Car
1)Disconnect and Isolate the - Battery Terminal.
2)PICTURE 2
Remove the wiring from the rear of the alternator.
After all of the wiring is removed then remove the remaining 12 mm nut from inside the plastic battery cable guide on the rear of the alternator and remove the guide.
3)PICTURE 3
Remove the three nuts holding the tin cover to the rear of the alternator and remove tin cover.
4)PICTURE 4
Remove the three Phillips screws holding the brush holder to the alternator and remove the brush holder.
5)Use the compressed air to blow out all of the dust in the alternator from the old, worn brushes.
6)Use the electrical contact cleaner or alcohol to clean the commutator and electrical components in the rear of the alternator.
7)When installing the new brush holder use the toothpick to depress the brushes in the holder while sliding it over the commutator.
8)Re-install all of the other components in the reverse order they were removed.
1
2
3
4
What is the part number for the correct brushes? I looked google it up and find many different types. Thx-Ace
The ND brush holder is the same for all Chrysler ND alternators.
Just look at the pic of the brush holder and compare to pic on eBay.
This is all I have to identify a Bosch/ND alternator.
I’m glad you brought this up.
I’ve been doing this on L-bodies also.
It’s such a cheap fix whether it’s the ND or the original Chrysler 78 amp.
I have a couple of (Chrysler 78 amp) sets in my parts box also.
Discussion Starter #11
I did not know the brushes were easily replaceable on the Chrysler Alternator, same procedure?
I believe so.
I remember the brushes being on springs and square end pieces that helped guide the brushes in.
They were screwed in to place.
1 - 13 of 13 Posts
