Ive got a 85 Daytona turbo and need to rebuild or replace the engine. I want to make some more HP, like about 250 or so. what should I do to make the engine stay together.... Im pretty hard on equiptment so I need to build it strong
What do you think of the 10 mm head bolts.I still have them in my 84,but only run 12psi-no IC 803s ported head ex&int mp computer.haven't had any trouble.The 85 engine is really tough, just a stock rebuild with Mahle pistons are needed for 300 WHP. The head is a great flowing G casting as well. Convert the car to T2 and run an 87 Stage 5 FWD computer setup and a nice big ebay intercooler. The trans in your car sucks, you need the newer shifter, cables, trans and axles. Cheap junk yard finds but needed as the A525 will explode.
drill them out and tap them, mopar used to sell the kit for 11mm bolts.What do you think of the 10 mm head bolts.I still have them in my 84,but only run 12psi-no IC 803s ported head ex&int mp computer.haven't had any trouble.
