My Daytona idles like crap. Sometimes it idles around 2000 and sometimes it barely stays running. Theres lots of black smoke comming out of the tail pipe. The boost gauge is going all over the place when its just idling. Whats wrong with it!!?? Is it the turbo? Any help will be greatly appreciated!!
good god! another victim of dried up crusty old vacuum lines. Go to the induction section and read up on the vacuum block sticky. once you get rid of the vac leaks life should be good(as long as the car is also tuned up -ignition wires rotor,cap plugs fuel filter )
VNT???? you're screwed!!
just kidding- also check the dodgegarage.com in the tech section I think common problems also if you can't figure it out PM NAJ he has a mint vnt and is a tech.
