21 - 24 of 24 Posts
Thank you so much, I'm so friggen nervous having to do this move. Very hard for me to concentrate right now.
I also have a rear-mounted battery that leads to a nest of wires under the hood, however, I did not find any broken fuses under the hood. (There are two attached to relays)
All of this happened after I shorted out the passenger side socket using a probe... sparks flew, then I no longer had the driver's side brake like or signal anymore.
My 86 Lebaron just did the same thing today and hitting the dashboard made the signals start working again. I think it's my radio wiring shorting out something. Also try turning the hazards on and off to see if the signals start working...
Hopefully I did not miss anything, any issues/problems/questions post back.
TURN SIGNAL CIRCUIT
Battery through OR Fusible Link to Fuse #10, Fuse #10 to Directional Flasher on the BK Wire, Directional Flasher to Turn Signal Switch on the RD Wire. Output from the T/S Switch to the Rear Directional Lights is on the DG/RD Wire (Left Side, DG Wire at Bulb Socket) and the BN/RD Wire (Right Side, BN Wire at Bulb Socket)
1)With the key on use a Digital Voltmeter or 12 volt test lamp check for power (battery voltage) in and out of Fuse #10.
a)No power = blown Fusible Link/Open Circuit from Battery to Fuse 10.
2)If power is present, check for power at the Directional Flasher BK wire.
a)No power = open circuit between Fuse #10 and the Directional Flasher.
3)If power is present place the T/S on, is power present on the Directional Flasher output RD wire.
a)No power = faulty Directional Flasher.
4)If power is present check for power on the RD Wire at the T/S switch.
a)No power = open circuit between Flasher and T/S Switch.
5)If power is present check the output to the rear directional lights on the DG/RD and BN/RD wires.
a)No power = faulty T/S Switch.
STOPLAMP CIRCUIT
Battery through OR Fusible Link to Fuse #6, Fuse #6 to the Stoplamp Switch on the PK wire.
From the Stoplamp Switch to...
High Mount Stop Light, on the WT Wire which becomes a WT/RD wire in the harness.
Left and Right Stop lamps, on the WT Wire (becomes a WT/RD and then WT again) to the Hazard Flasher Switch.
From the Hazard Flasher Switch to the Directional Switch on the WT Wire.
From the Directional Switch to the L/R Stop/Directional lights on DG/RD Wire (becomes DG in the harness)
From the Directional Switch to the R/R Stop/Directional lights on BN/RD Wire (becomes BN in the harness)
1)Verify power is present in and out of Fuse #6.
a)No power = blown fusible link/open circuit between Battery and Fuse 6.
2)Verify power is present on the PK Wire at the Stoplamp Switch.
a)No power = open circuit between Fuse 6 and the Stoplamp Switch.
3)Apply the brake and check for power on the WT Wire.
a)No power = Faulty Stoplamp Switch
4)With the brake applied check for power on both WT wires at the Hazard Flasher Switch.
a)No power on the WT input wire = open circuit between the Stoplamp Switch and the Hazard Flasher Switch.
b)No power on the WT output wire = faulty Hazard Flasher Switch.
NOTE: Be sure the Hazard Flasher Switch is Off.
5)
With the brake applied check for power at the WT wire at the Directional Switch.
a)No power = open circuit between the Hazard Flasher Switch and the Directional Switch.
Discussion Starter · #23 ·
Thank you soooo much for your write-up, I'm sorry I was unable to try it before I had to move!
I BARELY made it, and the last 10 miles was on a flat tire!
I couldn't even get out of bed the next day because I drove with my benchpress bench like in the photo, my back is still sore days later! Ugh!
Honestly, after driving my 1993 Voyager and the A523, I kinda wanna swap the Lebaron engine into my van... love the damn van so much!
Let this be a lesson to anyone... if you're going to move and ask the nice people of turbododge.com for help, don't wait until like 2 days before you move!!! I'll give those instructions a shot and see if I can fix my brake lights now that I'm finally almost settled in. Thanks for all the help guys.
Take your time, rest up, get settled in and when you are ready we will be here.
21 - 24 of 24 Posts
