1 - 12 of 12 Posts
Working on my 89 Daytona and one of the bolts got stripped taking the intake manifold off. I need one of the long bolts and I also need an exhaust stud too. It's non turbo. Any help would be greatly appreciated.
from the part book:
W/0 INTERCOOLER 2.2 L ENGINE
6500679 8 STUD, Exhaust Manifold to Cylinder Head
6500363 8 NUT, Exhaust Manifold to Head Stud
6501690 4 BOLT, Intake Manifold to Cylinder Head (M8x90) have one of these
6501689 4 BOLT, Intake Manifold to Cylinder Head (M8x65)
Hate to be the one to chime in with this, but the bolts are steel and the cylinder head is aluminum. If stripping occurred it’s more likely in the threads in the head.
Unless you mean the bolt head stripped.
But if it’s the threads, do yourself a favor and check the threads in the head. Repairs might be necessary.
remember too
the lower row of exhaust manifold studs go into the water jacket
.. so if you take one out , put a little sealer on it before it goes back in
all the other bolts & studs should be dry holes
new ex manifold nuts are always nice .. if you have to come back to it again later
I proly have both ;
can get a length of the needed IM bolt so we make sure to get the right one ?
remember too
Thanks for the info i didn't know that
The bolt head stripped and i knicked an exhaust stud with a cutoff tool
Discussion Starter #8
I proly have both ;
Thanks for the reply and sorry had some problems so i'm just getting back here. The intake bolt is the larger one on the 2.5l i think its about 3 inches but i can measure it when i get back to the car if you need me to. i really need that bolt cause i think i stripped an adjacent thread in the head. Thanks
from the part book:
its 2.5l 8 bolt intake to head
Discussion Starter #12
um those are parts for the 'Turbo' ..
which is why I'm asking for the specific dimensions
The intake bolt is 3.5 inch long the length to the bottom of the head. Do you have the torque number for the intake it should be in inch pounds. i lost my book
1 - 12 of 12 Posts
