question 1. YesI just picked up some new MP lifters.
They all don't behave the same. Out of 8 of them, a couple of them are really springy, a couple are hard as rocks, and the rest are of varying levels of springiness.
I can squeeze some of them as much as a 1/8th inch with my ultra-scientific thumb and forefinger testing method.
My questions are:
is this to be expected?
will the hard ones loosen up?
should the springy ones be harder?
am I overreacting?
All of the MP & MOPAR stuff I have bought before was from Chrysler. These lifters are from the Daimler era.
If you have bought and used MP lifters, I want to hear what you have to say!!
HAHA funny dude...question 1. Yes
question 2. You need to understand how lash adjusters work.
question 3. You need to understand how lash adjusters work
question 4. TOTALLY.
I build a lot of engines, besides 2.2/2.5. All engines with hydraulic lifters or lash adjusters, or lifter buckets (quad 4, VW, Vega and a few others). Anyway, get yourself educated in how hydraulic cams work. Go to your local library or book store and buy an Automotive Text book like what Highschool auto shops would use to teach the kiddies. Reading thru books like this is a great way to become more educated and will greatly improve your abilities to service your own automobile. If this task is too difficult, try an internet search of various cam companies. Isky, Crank, Crower, are all great sources that may answer this specific question. Try how hydraulic lifters work - Google Search
Plenty anybody else. You just too lazy to read?
Yup, I understand the concept of a hydraulic lifter...Plenty anybody else. You just too lazy to read?
Good tip. would thin oil be good for that?i submerge my new lash adj in a bucket of clean engine oil and leave them there over night or longer depending when i'm going to do the job. this process helps burp the air out of them so they don't clatter on first startup.
My questions are:
am I overreacting?
how did u go from 8 lash adj with a couple hard as my pee-pee to 8 diff lifters that act 8 diff ways. are you embelishing the story or just being goofy? if u feel ambitious u could take apart each adjuster and make sure there's no oil in them cuz that could be why its hard, or u could check the check valve to make sure that they are in proper working condition cuz a stuck one could make it hard too, or u could check to make sure there's no rusting inside cuz that could also be hardYup, I understand the concept of a hydraulic lifter...
No, not too lazy to read, just couldn't find anything to tell me why I got 8 diff lifters that act 8 diff ways...
y not just use the same oil that'll go in the motor, all i ever did cuz figure when the engine starts, what goes into the lash adj?i submerge my new lash adj in a bucket of clean engine oil and leave them there over night or longer depending when i'm going to do the job. this process helps burp the air out of them so they don't clatter on first startup.
I'm just frustrated.... so yeah goofy...how did u go from 8 lash adj with a couple hard as my pee-pee to 8 diff lifters that act 8 diff ways. are you embelishing the story or just being goofy? if u feel ambitious u could take apart each adjuster and make sure there's no oil in them cuz that could be why its hard, or u could check the check valve to make sure that they are in proper working condition cuz a stuck one could make it hard too, or u could check to make sure there's no rusting inside cuz that could also be hard
no not really ; noticing things like that (replacement prts dont seem "right") and realizing that there MAY be a problem is a very important skillI guess I am over-analyzing ...
Ok cool... do you think I'll have any problems with the hard-a$$ ones?no not really ; noticing things like that (replacement prts dont seem "right") and realizing that there MAY be a problem is a very important skill
going to a forum for info is also intelligent
be patient ; do your research on this forum and others ; filter thru the feedback that the greybeards give ya.. and filter thru the crap too
you'll find that if you submerge the soft lifters in some engine oil, and squeeze them couple times, they will suck some oil inside and firm right up nice !
a good question taht I dont know the answer toOk cool... do you think I'll have any problems with the hard-a$$ ones?
like Hanging valves or them getting stuck down on assembly?
I guess what I'm worried about is whatever is keeping them stuck out will keep them stuck in on assembly.
I don't get why you're snapping on me. I'm listening to what you're telling me...holy crap, so that's why i was doing that, i just thought it would be a good idea.
I just tried (don't laugh) leaning on them to put pressure on the spring to make them collapse... I had luck with all but one. Maybe I will try that Vise trick.a good question taht I dont know the answer to
I know on my DSM I was told to 'collapse' all 16 lifter in a vice to make them 'spongy' before install, with the rationale that as the engine oil P came up and filled the lifters, they would expand to just te right amount
do u know how to compress a lifter/lash adj? i read in my ford book to put it in a vice and gently compress it. maybe u could try that so see whats up with it.Ok cool... do you think I'll have any problems with the hard-a$$ ones?
I hear what you both are saying. I will do that.do u know how to compress a lifter/lash adj? i read in my ford book to put it in a vice and gently compress it. maybe u could try that so see whats up with it.
This place has really needed an industrial-sized crap filter lately. Some people just don't think that anyone but themselves can work on a car. I had to deal with the same BS when I worked at a dealership. It gets a little old. If people didn't have questions, then what the hell would be the point in having a forum? Maybe there's a slight chance that people who post questions have exhausted all resources that they could find, become frustrated, and post a question that they could possibly have answered on their own later on. If you don't have anything productive to say, then why post, only to put someone down and give yourself a false sense of self-esteem. If it's not productive, but makes you feel cool, then why not? :bash:.......and filter thru the crap too![]()
