So I FINALLY just got done installing my G-head, port and polished, along with my S60 and ported exhaust manifold, also ditched the balance shafts (and plugged the hole!). All new gaskets, seats, etc. Head studs as well.
I fired it up, ran like crap for a few minutes then started to get normalized. Once it did, took it around the block. Light on it at first, then tried getting on the throttle a bit... this is where I found a problem.
It has NO low end. The spool doesnt kick up till about 3500-4000 RPM! My stock Mitsubishi spooled at like 2K near full boost... Even holding the brakes and giving it gas wont let it build ANY boost.
Does this require break-in to the new turbo? Could my timing have gone off from the difference in heads and turbo? Ill check timing and AFR tomorrow, but wanted to extra advice from anybody who might have some ideas.
