I bought my 1987 Shelby Charger GLHS in late 2017 and the car ran great for the first two ½ years. Never one to leave a good thing alone I decided to dress up the engine compartment for cruise nights and car shows with a cone intake and an aluminum upper intake hose and a few other things. I pulled the old AirBox assyand cleaned all the grease and grime that accumulated over the 32 years. When I started the car back up with the new intake parts installed I had zero boost. It was so lacking that the lower intercooler hose was collapsing from the intake manifold pressure,.Driving the car was impossible with it choking out at 35 MPH. After testing the wastegate can and finding it functional I assumed the swingvalve disk had broken loose and the valve was dumping the boost.
It was around this time that my back gave out and i was in the hospital for back surgery #3 which ended any work I could do on the car for the extended future.
After surgery, now over a year since the problem started I came into a few bucks and decided to purchase an upgraded Garrett turbo from Turbos Unleashed and new 2.5 in swingvalve and a 3” exhaust from FWD performance. Since I couldn't do this modification myself I sent my car to a reputable restoration shop in my town and had them change the turbo/swingvalve and install the new 3” exhaust, no cat and a magnaflow muffler.
For the next three months they had my car trying to solve the problem, they had me buy and replace every sensor on the car, a replacement logic module (Stage 3 from FWD), and then installed a vacuum block and all new silicone vacuum lines. Still NO BOOST! At this time after charging me $4K in labor and parts they told me they were giving up on the car and it is costing them time and is backing up their shop and to come and pick up the car.. They even had the gall to tell me I actually owe them another $800 for the vacuum setup but they would let it go. What a bunch of “nice guys”.
Since I have finally been able to work on the car a few months later I have changed to a bigger watergate can with an adjustable arm and have tried to make the wastegate arm so tight it couldn't possibly open the actuator, test drove it and STILL NO BOOST! I can hear the turbo whine like crazy so it is doing something. Figuring that I must have a Boost leak, I setup a Boost Leak test using a hand made setup and I can get the car to hold steady 18 psi all the way through the intake system. Again I test drive it and still NO BOOST! Also I have run a direct line from the vacuum block to the wastegate can running through a grainger valve tightened all the way in and the car just won’t accelerate, when it feels like the boost should come in, it goes flat.
I am at a loss as to what the problem could be, where is the boost going, Both turbos are fine, the original one that was pulled shows little wear or endplay, the car has 54K miles. The replacement is a rebuilt unit from TU with the quick spool option but neither will produce boost in this car, I would expect overboost from some of the attempts I have done but NO BOOST.
Any suggestions or a mechanic in the New England area that might be able to help. The weather is getting nice and this car has been sitting now for almost 2 years and I would really like to enjoy it again.
I appreciate all who took the time to read this extensive post.
