1 - 2 of 2 Posts
Hey all,
Went to nippo alt, and still have a low / no charge situation. I am trying some rewiring now and am looking for some input. I have the original harness and am using it. I am now trying to put in new wires to the regulator. Can I bypass and go direct from the field terminals to the regulator? Do I need to splice the blue into the harness where it was at the regulator, or can it stand alone?
double check the ground wire off the pass side head
double check the ground wire from near fuse box has a small sheet metal screw into the inner wheel well -- common for this to rust out leaving the wire dangling
1 - 2 of 2 Posts
