1 - 2 of 2 Posts
*Before performing diagnostic tests check for any fault codes that may be
present.
If fault codes are present, clear them(battery disconnect) and crank
the engine for 10 seconds and recheck codes.
If codes are present repair them before continuing.
*These tests can also be run on 91 up(except T-3)but the DB/YL wire was
removed from the diagnostic connector so you cannot actuate the ASD as
it is listed in step #3.
*Due to the length of diagnostic charts and changes made from year to year
if specific diagnostics are needed for ASD,HEP,Coil Control circuits contact
me for specific info related to your year/model/engine.
1)Verify no spark by removing the coil wire from the distributor cap and hold
1/4" from a good ground.
Text Line art Font
Text Font Design Line Diagram
Crank the engine for 7-10 seconds, spark should be strong and consistent
Count 1-2 sparks as No Spark.
Is spark present?
Yes...Recheck at a spark plug, if spark is not present at the plugs the issue
is with the secondary ignition(cap, rotor, wires)
If spark IS present your issue is intermittent or not ignition related, move to fuel system diagnostics
No...continue
2)Verify...
Distributor is turning, if distributor is not turning repair timing belt issue.
Coil wire is not open, check resistance with an ohmmeter,3000-5000 ohms
per foot. Repair as necessary.
Are distributor and coil wire OK?
Yes...continue
3)Check ASD Relay circuit(84-90)(On 91-up do you hear the fuel pump cycle for 1 second with initial key on?)
Locate the underhood diagnostic connector
With the key on/engine off ground the DB/YL(dark blue/yellow) wire.
This will actuate the ASD relay.(A Code 42 will be set in memory)
Power (battery voltage) should be present at the + coil, DG/BK
(dark green/black) wire at the injector(s) and at the fuel pump.
You should hear the fuel pump running.
Is power present?
No...Repair ASD Relay circuit
Yes...continue
4)Check HEP (hall effect pickup) circuit.
Remove the ground wire from the diagnostic connector.
Using a 12 volt test lamp connected to + coil and ground crank the engine.
The test lamp should illuminate.
Did the test lamp illuminate?
No...Repair the HEP circuit
Yes...continue
5)Check coil control circuit
Using a 12 volt test lamp connected to - coil and ground crank the engine.
The test lamp should flash on/off repeatedly.
If the lamp flashed on/off but no spark...replace the ignition coil.
If the lamp did not light...replace the ignition coil
If the test lamp illuminated but did not flash...repair the coil control circuit.
MANUALLY ACTUATING THE ASD RELAY
Wire Technology Electronic device Auto part Cable
Discussion Starter · #2 · (Edited)
Also on 85-87 once the battery is disconnected and before the engine is cranked again there should be a Code 11 in memory(engine not cranked since battery disconnect).
Once the engine is cranked the Code 11 should no longer be present.
If it is the controller never saw a crank signal from the HEP.
Let me know if you need specific diagnostics for a circuit.
1 - 2 of 2 Posts
