1 - 9 of 9 Posts
Do I really need one?I have a wideband and I don't have a bung so can I just take the o2 and put the wideband o2 in it's place
Your cal relies on your O2 sensor at anything less than WOT, so unless you are dragstrip only, you will want one.
Legendary Driver
what wideband do you have? An LC-1 from innovate can send a simulated narrowband output to the ECU so you dont need a stock O2
This is what myself and a buddy of mine are doing. Just plugged the stock hole up and use the analog (narrowband) sim signal from the LC-1 to the computer. Works good last long time :thumb:
Legendary Driver
well 1st any exhaust shop can weld a O2 bung onto your exhaust, should have them in stock. If you also want to remove your stock O2 and plug it you can get a bung/plug kit from Innovate. I don't know if you can run the ECU off the AEM setup. I've never heard either way and their website sucks for instructions. Part of the reason I went with Innovate.
1 - 9 of 9 Posts
