I'm not knowledgable with writing on turbododge and can barely find my way around it, I'm sorry if I am incorrectly jumping into a discussion...I am at wits end with trying to find the problem with my 84 rampage and it's driving me bonkers..it's the naturally aspirated version and when started it runs very well with minimal problems except maybe a quick stumbling, stall twice as it is warming up( about 1 second ). After warming up it runs with a sound like a valve ( light misfire )stumble which happens every 3 to 5 seconds and 50% of the time sounds like it has as if it were dieseling or rod knocking, if I shut it off and restart it it will most times runs absolutely perfect for up to 10 minutes then start to slowly misfire lightly again and seems to get very hot to the touch on the carb and intake. When I shift from P to R to D (auto) it shifts Hard and accelerating from 0-30 it bogs a little and 30+ it scoots but runs rougher at idle on a short trip. I have tried things 1 at a time: pcv and eliminated small leaks, rebuilt old carb, purchased brand new carb, new vacuum lines, new plugs, wires, cap, rotor, timing, fuel filter, fluids, removed ac belt, checked ecu/esa for flaws in electrical board...last 2 things I can think of is egr and replacing ecu unit ..any thoughts would be helpful..great little backup vehicle but not if I can't drive it. Thanks
