Finished this rare 1984 DC Rampage this Summer.
Features include a ...... 2.2 turbo II motor
Rod shifted A555 w/ Heim Joints
1989 Caravan turbo engine bay harness
1985 Shelby Charger turbo motor mounts
1985 Shelby Charger turbo stock exhaust
1988-89 Daytona 2.2 turbo II SMEC
GLHS Radiator Intercooler
Stock Rampage front & rear springs for hauling stuff.
87 Shelby Lancer wheels with 205/60VR15 tires
GLHS Radiator fan
1989 Daytona vacume harness,solenoids,relays
1989 Caravan starter,water pump,120 amp alt.
( Dome light does not flicker anymore )
1987 GLHS dash cluster plugged into the 84 rampage
dash wiring harness with the correct wires added.
1989 Omni TBI gas tank and hangar with walbro pump.
Reinforced front core support with more metal added
for increased power on the front end.
Shelby Charger turbo front hubs with all new parts.
1988 CSX rear disc brakes with some custom made
lines, along with a shelby Daytona master cyl.
Pigtails modified.......
Wiper motor,back-up light,neutral safety,oil pressure
sending units, bulkhead caravan 50 pin to l-body 40 pin,
headlight plugs & front turn signal length.Map / Bar
sensor was re-located to passenger fender
Two wires were added for for the charge temp sensor,that
Caravan harness did not have.
The caravan harness length is much longer,with extra
accessories. Lots of wires were taken out to save on
bulk..... while others were made longer or shorter for
the Rampage engine bay. We picked up a extra engine
bay harness just for the extra wire and connectors.
