Hey Dave, I tried emailing you. Never heard back.
On another note, I sanded down some rust spots on the body and put primer on them, finished rebuilding the head, rebuilt the HVAC housing, removed the entire AC system, fixed the gauges not working, removed the fuel vapor system, replaced the wheel bearings and painted the knuckles, coated the exhaust manifold, painted the camshaft sprocket and some more that I can't recall. I will post pictures once I really make some headway on installing it all. I came across an odd problem when I was replacing the LCAs though... Apparently the Moog LCAs are oversized by .075" to compensate for worn knuckles? And some other manufacturers are as well. Made me pretty upset when I went to install them and they clearly werent going to fit without reaming out the knuckle. So I returned them and ordered Rare Parts ball joints that I'll be pressing into the original arms after I paint them as well.
Parts awaiting installation: water pump and timing belt, rear brake lines, front brake lines, caliper rebuild kits, brembo brakes, all new engine sensors, full engine gasket set, EGR block off plate, heater core, thermostat, ignition coil, spark plugs and wires, radiator hoses, brake pedal pad, cat delete pipe, Mopar performance head gasket, new head bolts, and I am sure I am missing some other things.
Kind of sad that I am doing all of this work on parts that I'll be stripping from the it here in a couple years.
