481 - 500 of 605 Posts
wiring electrical for a 1984 Rampage
Hello
I have a 1984 Rampage and the electrical need to be redone. Someone directed wire the radiator fan to a switch in the cab. a wire keeps burning out. Does anyone have a wiring diagram or know how to repair all the wires? Thank you
Re: wiring electrical for a 1984 Rampage
Hello
Welcome to TurboDodge!
So there's another Rampage here in Texas, very good. I'm east of Denton.
You're best bet would be to get the Factory Service Manuals (2 books):
https://www.ebay.com/itm/1984-Chrys...=item2a8c64922b:g:UPkAAOSwR21ZzTHC:rk:46:pf:0
One of them (Electrical) has the wiring diagrams and also figures of the harness routing.
There's more of them on Ebay…
I had to redo my front harness and replace some wires and connectors. Spliced, soldered & heat-shrinked using the same color & gauge wire. Used split loom tubing (nylon not the cheap stuff, it'll melt) to finish it off as per the manual's figures. In hindsight I should have taken the harness out of the car and saved my back lots of pain! Be careful of the connectors, they're brittle. Clean all the contacts and apply dielectric grease to them. This may seem to be a lot of work now but it'll save you time later looking for electrical gremlins.
Good luck!
I have the '83 manuals but I believe that some things changed in '84.
For example, you can get codes by turning the key ON-OFF-ON-OFF-ON (not start) within 5 seconds and my '83 is unable to do this.
Check out this link for the Factory Parts Manual:
http://www.glmwpg.com/ServiceManuals/84p.PDF
If you have any questions feel free to post them. I and others I'm sure will be glad to help!
· Premium Member
Welcome David (Hassle) Hoff to the wonderful world of the Rampage. I have an 84 myself, but it's far from stock. When I bought it, it had a manual switch under the dash for the fan. I wasn't used to that, and there were times I left it on and drained the battery, or the times the temp gauge kept climbing and had to pull over and pull a Homer (DOH).
I cut the switch and installed a Flex-A-Lite top of the line fan controller and it's so much better. Variable speed, temp sensor, and runs the fan Cor a short time after the engine stops to cool down the engine.
I wished there were more Rampage owners here in Central Texas. Must be all those wide open spaces up there.
I used to live on the corner of Gallant Fox & 1826 just south of 280 west of Oak Hill. I left TWO '83 Scamps in one of the wrecking Yards on South Congress when My Bride and I re-located north ah few years back. We moved 6 Mopars and I just couldn't justify another trip back for the last two. Probably been recycled to China by now. I know of one guy in San Antonio that has a 'Page. Try to hook up with the S.A. Mopar Club. Much friendly'er then The Austin Mopar E+B Body bunch. Back then I was into A+C+& L body's and they wouldn't even talk to me, Jer
There in Ft Worth? They've done tons of construction around there and are still at it. You wouldn't know which way is where now!
Hey, anyone know where to get the clips for the black metal trim that goes outside below the back window? A fellow member sold me the trim piece but I'm needing those clips...
Thanks for any info!
Ok all you Rampage owners, please help me on the following:
Got my '83 without the storage tray nor the moulding underneath the window. Thanks to a fellow member I now have both. From looking at the parts manual and finding only 2 images on the net it appears that there is carpet attached to the rear body panel from the tray upwards to the moulding.
Is this correct?
If so, does the carpet have some sort of backing to hold it up? How is it attached?
Secondly, what about the jack instruction labels? Surely these weren't covered up or were they placed in another spot? But where? There isn't any other place that I can tell.
Trying to do a restore so any help or info will be appreciated!
carpet in my 82 is attached to cardboard material (like door panels) and then backed with carpet pad for sound proofing. the cardboard sandwiched in the middle has two 'ears' or tabs, sheet metal screws go through these into the raised portion under the window and are covered with the trim piece. best of luck with the resto.
I think everyone has deserted this thread and moved on to another.
Tom
Not so Tom. Theirz a wealth of knowledge here just catching our collective breath and taking naps. I'm still looking for the source for those clips for that rail beneath the back glass so I can enlighten John. I don't loose sources where I find stuff for ANY of my toyz. My file cabinet iz just too stuffed to put my hand on that receipt rite now, Jer
Thank you guys!
So what about the "Jack Instruction Labels"? With the 2 tabs: does this hinge the carpet panel to access the labels? I'm trying to figure this out. Why would Chrysler cover up the labels? Of course we have asked many time why Chrysler did a lot of things! LOL
Have corresponded with Wes. He's still debating whether to make the clips with his 3D printer. He needs the clips also so hopefully he'll decide to do it...
Based on your pic John I'd say that those instructions were right where your picture shows them to be, under that carpeted cover on the bulkhead below the back glass. My Scamp never had them glued on there. I stripped the trucklet when I changed the color, NONE THERE BEFORE THE RE-SHOOT? Jer ... Still looking for that clip receipt?
So you didn't have any labels? Maybe they were removed sometime in the past before you got your Scamp. Seems all cars have them in one place or another. Maybe another owner will chime in???
In the "82 I have the carpet is stationary and as far as I can tell it didn't have the jack instruction labels, but it was not treated very well by previous persons. They have been removed.
Didn't I see somewhere in a past post someone claimed that there was a ford clip that would work on trim under rear glass?
Well now I'm wondering even more! My Rampage was a special order for the GSA. The Corp of Engineers used it somewhere around here, probably around one of the lakes that they manage. When I got my Rampage it didn't have the window trim, carpet on the panel nor the storage tray. There were some sort of electrical junctions attached to the back panel and a switch (like the old headlight high beam switch) in the floor board by the driver's left foot. Maybe these were for emergency lights or some sort of emergency equipment that the Corp used. Someone later put a carpet covered piece of plywood over the panel with 2 speakers installed. All of this I've pulled out now.
Either the Corp took out the trim, carpet & tray or Chrysler built it that way and put the jack instruction decals there on the panel. But if one looks carefully at the decals they ARE for the Rampage Model. So my question still remains on the location of the decals. Hidden underneath carpet? Might be so, where else could they be applied? Surely other Rampages/Scamps had them...
Not this one I think John. With the help of a friend I Intercepted this one as it came into a wrecking Yard in Helena, Mt. on a rollback to be scrapped. My friend was in that yard when it came thru' the gate. Got the original Montana title that waz dated 10/82. that the owner had just signed off in July of 2003. I won't bore you with the whole story but I had it delivered to our home in Chelsea, Mi. 5 weeks later and drove it off the haul trailer, Jer
Well the mystery continues. Perhaps the decals weren't a required item on vehicles. Maybe Chrysler had a "dress-up package" option for the back that included the carpet & tray so no decals to waste money. I did notice that the bottom brackets for the tray have no holes drilled for the tray's mounting screws.
Ha! I've got a rare Rampage! Only one with jack instruction decals! :smile2:
I think you just answered your own question John. I'm sure you can figure out where to bore the holes in the mounting tray brackets if the holes are already in the tray? You have one of 40,000+ 'Page's, plus another 4,100 Scamps? Damn, you won't even wanna talk to us regular folks, lol. I'm still hunting for my receipt for the new molding clips to mount the plate under the back glass. 7 of 'um if I remember rite? Jer
Yes, there's 7 of those clips needed. Look like little aliens with antennas! LOL
Now I need help to make a decision: should I put in carpet on the panel or leave the carpet off to show off my decals???:cool:
