I'm back guys. 89 Caravan 2.5 turbo. Oil light is staying on sometimes when I start car. It did something like this about 1 1/2 yrs. ago. Wouldn't go off at first so I bought a gauge, then it stopped doing it, so I never put gauge on. Now for the last week or so, sometimes when I start the car the light won't go off or it stays on for a longer time. If it stays on, I shut it off. Few minutes later, it's okay. But today I tried to start it like 5 times and light would not go off. Then after like 5 mins. started and ok. Started it a few more times and ok. What is going on?
Your issue could be a faulty sending unit or a mechanical engine issue.
First you need to verify actual oil pressure with a mechanical gauge.
Oil Pressure Specs(Chrysler)
At Idle - 4 PSI Minimum
At 2000 RPM's - 25-75 PSI
General rule of thumb is 10 PSI for every 1000 RPM's.
@ Tryingbe, can ya come over and put it on for me? Ya see, I just lost my mechanic cause he moved out of town and I'm trying to find someone else to take his place. If I knew how to do it and I had all my tools (that were stolen out of garage) I might give it a shot. But I don't, so give a girl a break. I know quite a bit but definitely not everything!
Hey NAJ, or whoever can answer this. Do I have an oil sending unit, or just an oil pressure switch? Cause I just changed switch in Aug, (had a leak). Any diagrams on changing switch.
There is a large SDAC chapter in Chicago. Go over and join turbo-mopar.com, and hit up some of the folks there. I'm sure you would be able to find a few guys willing to help you out. Join SDAC while you are at it, that will definitely help grease the wheels on getting some good quality help...
Shelby Dodge Auto Club
OK, found out only oil pressure switch, but also found out I have a crack in the front of my frame. If I get it welded, is it still something I'll have to check periodically. Can't believe nobody ever noticed this.
@83scamp, already working on the SDAC thing. Thanks for heads up on turbo-mopar.
