That is one amazing block! Do you know if that is ceramic paint? First off I was floored, then amazed at both the color coated inside of that engine block (have never thought about doing that ever, but I bet the oil just slides off all those surfaces smoothly where it does not need to have oil cling. And I love both of those designs, but the crank scraper and windage screen design is really beyond nice, no doubt did the job perfectly.
I take it those tapped attachment holes did not exist in the block originally, and he machined them and tapped them...must really need to have the oil and water passages details down pat to avoid hitting anything on the prep of the mounting holes, but 1/2"-3/4" studs is all that is needed, and easy to see he attached 3 bolts front, 2 rear, and the crank is easily clear since the pan is plenty deep and he kept the sump side clear for the oil pump and pickup.
Am going to my machinists shop tomorrow, where my short block is awaiting pistons from Ross and the further work, so will discuss it with him and review the pics with the required mounting points, see if I can get those 5 holes done also, I can fab the rest, and there is a very reasonable metals supplier and plasma cutter here in town I used for my fuel cell area bulkhead upper and lower, and hole blocker plates when I removed the firewall, and wiper items that cuts beautifully so I just do a final edge grind then they custom bend with their brakes perfectly.
Thank you for sharing, as it was just exactly what I was looking for. To see that is to want just that.
Forward motion brings all the oil to the rear sump area, the arch and scraper in coated screen form is perfect. And 8 bolts, 3 straps, and the screen light enough, and anti-HP robbing more than makes up for the added wt.
Wow.
Bottom 1 is also a very nice simple pc. But their rule is plain and simple, and enforced...Windage trays ok, but zero modifications to the oil pan. Some allowed aftermarket OEM fit pans though, but have not seen 1 yet, for the 2.2L I have, at least not yet.
And it is the 5 qt. Pan.
