92 daytona, 3.0L
I'm replacing my head gasket, and taking the opportunity to replace as much stuff as I can while everything is apart. The oil pump is on that list. I have everything off, except I cannot get the oil pump off. I've removed 5 pump mounting bolts, and 4 oil pan bolts that go into the pump housing. I can wiggle the pump, and move it out ~1/4 in, but it seems to be catching on something. I do still have the oil pan on, does it need to come off? I'm supporting the engine right now through the oil pan, so im trying to avoid that if possible.
