1 - 20 of 28 Posts
I have a base model Horizon(handling that is). What parts off what cars can I put on this to make it handle better on the cheap I.E no KYB's or hi dollar springs. Just your basic this had that, use it to do this.
Criag you really need stiffer springs:nodding: The struts and shocks are to aid in stablizing the responce the springs and tires take on with bumps and dips in the pavement. The shocks/struts are important for what they do, but the one's you have on hand I think would do more wonder's then you may think with a stiff spring.
I have a new set of lowered L body springs from FWD I never put on. Went with coilovers instead. $200 obo shipped.
Front and rear from LRE. $325 total from FWD.
They've been sitting in my garage for a while now, never put em on the car. I can post pics for those interested.
well of course the simplest and cheapest would be to upgrade from "base" to "GLH" level springs & sway bar(s)
you should be able to get GLH (or identical SC) springs for 20-40/pr (I have some FS)
you could also trim a coil or 1.5 from your stock springs which will lower your car *and* stiffen the spring, both aiding in handling (and free)
then upgrading to at least 14" wheels (maybe some charger 2.2 'road' wheels) with e.g. 185/60-14 or better yet GLH/SC spec with 15x6 pizza wheels and 195/50 or 195/60-15s will help A LOT in handling
wont cutting the springs give you more of an ocean liner effect? Unless you add new shocks, the reduced rate will make the car bounce a lot, no?
Discussion Starter · #12 ·
I've got the 185/60-14's off a Geo storm now, Can't go to low on the springs or the header might bottom out on a good Oklahoma road.So Let me get back to you on the those, I've got a deal working to get a few bucks. As for the wheels... I bought a 1984 Shelby N/A new(wish i still had it) the handling on that thing was great!!!!!! I believe it pulled a .9 on the skid pad. Anyway the 4 lug Pizza's are hard to come by, I have a good friend that has a few 5 lugs he's offered but really don't want to change the hubs, I'm still looking for the 4 luggers. What about boxing the rear channel with some angle? I noticed when chancing the shocks the other day that it's has quite a bit of flex. Keep it coming guy more ideas the better TIA
I know that if you are looking for a set of 15" rims, I know that I have a set that were from what I think is a Saturn, but they are 15x6 I think.
I am pretty sure that they are aluminum, it is either that or magnesium, I know that they are not steel.
Could do a set of coilovers and neon suspension in front. That's how I did my Rampage.
it is almost like the first one, and if there were true, then they are really light then in comparison to the 5-lug 15" wheels. And these are 15"x6" so they would be comparable to the other TD rims.
1 - 20 of 28 Posts
