paint my crabs ??
522 Views 2 Replies 3 Participants Last post by  bfarroo
got a set of 6.5 crabs and the clear is peeling so i wanna paint them, what should i do and how do i do it ??
i just got some crabs like that and i used one of those rust removing wheels for a drill and used it around the outer rim of the wheel. You need to be careful on the face of the wheel which is a little rougher because it will scratch easy with that wheel. Try finding a finer disc to sand it with.or maybe just use an airplane stripper? i ground mine down then washed them and used duplicolor graphite color rim paint and then used the same brand rim paint clear coat. the graphite is pretty dark but looks nice on my van. 2-3 coats of each looks nice. autozone has some brand of rim paint but is expensive. i got this stuff from meijers for about 3.50 a can. one can of graphite and one can of clear and we were good to go.hope this helps
aircraft remover works good on the outer edge of the rim where the aluminum is clear coated. Doesn't affect the powdercoat much on the center unless you leave it on for a really long time. I sprayed mine with the remover trying to keep it off the center. Let it sit for 5 min and then scrubbed with a old toothbrush. Rinse with water. Make sure you use some chemical gloves when using this stuff. Then sanded outer edge and polished with mothers.
Benji Farr
Green Bay WI
87 Shelby Z TII 15.2 @ 90.7
88 Shelby Z TI 2.2 auto
91 Shelby TI 2.5 5spd
http://bfarroo.tripod.com
http://www.extremepsi.org
