INSTALLATION
The PCM engine control strategy prevents reduced idle speeds until after the engine operates for 320 km (200 miles). If the PCM is replaced after 320 km (200 miles) of usage, update the mileage and vehicle identification number (VIN) in the new PCM. Use the DRBIII® scan tool to change the millage and VIN in the PCM. If this step is not done a diagnostic trouble code (DTC) may be set and SKIM must be done or car will not start if it is a SKIM equipped car. If a SKIM car you must do a secret key transfer also. Refer to the appropriate Powertrain Diagnostic Manual and the DRBIII® scan tool.
Install PCM. Tighten bolt to 4 N·m (35 in. lbs.) torque (NGC MOUNTING).
Reposition wiring harness.
Connect the 4 PCM electrical connector (NGC CONNECTORS).
Reposition the washer bottle filler neck and install the bolt.
Connect negative battery cable and reprogram radio and clock.
Using DRBIII® scan tool, program mileage and vehicle identification number (VIN) into PCM. Refer to the DRBIII® scan tool and the appropriate Powertrain Diagnostic
STANDARD PROCEDURE - PINION FACTOR PROCEDURE
The vehicle speed readings for the speedometer are taken from the output speed sensor. The PCM must be calibrated to the different combinations of equipment available. Pinion Factor allows the technician to set the Powertrain Control Module initial setting so that the speedometer readings will be correct.
This procedure must be performed if the Powertrain Control Module has been replaced. Failure to perform this procedure will result in an inoperative speedometer.
To properly read or reset the Pinion Factor, it is necessary to use a DRB scan tool. Perform the following steps with the DRB scan tool to read or reset the Pinion Factor:
Plug the DRB scan tool into the data link connector located under the instrument panel.
Select the Transmission menu.
Select the Miscellaneous menu.
Select Pinion Factor. Then follow the instructions on the DRB scan tool screen.
STANDARD PROCEDURE - PCM/SKIM PROGRAMMING
NOTE: Before replacing the PCM for a failed driver, control circuit or ground circuit, be sure to check the related component/circuit integrity for failures not detected due to a double fault in the circuit. Most PCM driver/control circuit failures are caused by internal component failures (i.e. relay and solenoids) and shorted circuits (i.e. pull-ups, drivers and switched circuits). These failures are difficult to detect when a double fault has occurred and only one DTC has set.
When a PCM (SBEC) and the SKIM are replaced at the same time perform the following steps in order:
Program the new PCM (SBEC)
Program the new SKIM
Replace all ignition keys and program them to the new SKIM.
PROGRAMMING THE PCM (SBEC)
The SKIS Secret Key is an ID code that is unique to each SKIM. This code is programmed and stored in the SKIM, PCM and transponder chip (ignition keys). When replacing the PCM it is necessary to program the secret key into the new PCM using the DRB III. Perform the following steps to program the secret key into the PCM.
Turn the ignition switch on (transmission in park/neutral).
Use the DRB III and select THEFT ALARM, SKIM then MISCELLANEOUS.
Select PCM REPLACED (GAS ENGINE).
Enter secured access mode by entering the vehicle four-digit PIN.
Select ENTER to update PCM VIN.
NOTE: If three attempts are made to enter secure access mode using an incorrect PIN, secured access mode will be locked out for one hour. To exit this lockout mode, turn the ignition to the RUN position for one hour then enter the correct PIN. (Ensure all accessories are turned off. Also monitor the battery state and connect a battery charger if necessary).
Press ENTER to transfer the secret key (the SKIM will send the secret key to the PCM).
Press Page Back to get to the Select System menu and select ENGINE, MISCELLANEOUS, and SRI MEMORY CHECK.
The DRB III will ask, Is odometer reading between XX and XX? Select the YES or NO button on the DRB III. If NO is selected, the DRB III will read, Enter odometer Reading<From I.P. odometer>. Enter the odometer reading from the Instrument Panel and press ENTER.
PROGRAMMING THE SKIM
Program the vehicle four-digit PIN into SKIM.
Select COUNTRY CODE and enter the correct country.
NOTE: Be sure to enter the correct country code. If the incorrect country code is programmed into SKIM, the SKIM must be replaced.
Select YES to update VIN (the SKIM will learn the VIN from the PCM).
Press ENTER to transfer the secret key (the PCM will send the secret key to the SKIM).
Program ignition keys to SKIM.
NOTE: If the PCM and the SKIM are replaced at the same time, all vehicle keys will need to be replaced and programmed to the new SKIM.
PROGRAMMING IGNITION KEYS TO THE SKIM
Select PROGRAM IGNITION KEY'S.
NOTE: A maximum of eight keys can be learned to each SKIM. Once a key is learned to a SKIM it (the key) cannot be transferred to another vehicle.
If ignition key programming is unsuccessful, the DRB III will display one of the following messages:
Programming Not Attempted - The DRB III attempts to read the programmed key status and there are no keys programmed into SKIM memory.
Programming Key Failed (Possible Used Key From Wrong Vehicle) - SKIM is unable to program key due to one of the following:
faulty ignition key transponder
ignition key is programmed to another vehicle.
8 Keys Already Learned, Programming Not Done - SKIM transponder ID memory is full.
Obtain ignition keys to be programmed from customer (8 keys maximum).
Using the DRB III, erase all ignition keys by selecting MISCELLANEOUS and ERASE ALL CURRENT IGN. KEYS.
Program all ignition keys.
Learned Key In Ignition - Ignition key transponder ID is currently programmed
