1 - 5 of 5 Posts
i know my car felt way tighter with the front poly bishings from napa
but what about the rear bushings that polybushings offers any noticable diffrence?
Legendary Driver
depends on the rear axle. For a 86-89 shelby rear axle, No. Why? because the rubber is harder than the race poly bushings. For base models and the 90+ bushings then yes the hard poly will help. But i'd upgrade the rear panhard bar 1st.
This is not true. I do have "street" poly and "race" Hard poly. The stock rubber was soft compared to the harder poly.
Johnny
Legendary Driver
Actually Johnny if you remember i have a set of your "race" poly bushings. And the stock 86-89 C/S or shelby solid rear sway bar axle bushings are harder. The base model/small sway bar bushings are softer for sure. Along with the 90+ bushings like i said above. Just put a 86 C/S rear axle in my new yorker and yes the stock bushings in that car were soft.
I burned the bushings out of my rear axle in my shelbyZ before realized they were and put in your street bushings. Then i sent them back because they were way way too soft and got the race bushings. Now the Race bushings are harder than the street there are still a bit softer than the stock bushings that were in the car. I have another ShelbyZ now and will be leaving the bushings stock on it. And the T-top car with it's "Race" bushings will be gotten rid of along with the bushings. Here's a couple pics and a quicktime video of the "street" bushings. Polybushings "street" rear axle bushings
But like I said if you have the early axle with the small sway bar or any of the 90+ rear axles then the poly bushings might be an upgrade.
1 - 5 of 5 Posts
