A few Questions ;
Was this problem present before you did the Engine work?
Did you Disconnect the Coolant Temp Sensor with the Engine Running when you set the Ignition Timing?
When the Engine is Cold and the Stalling Condition is Present will the Engine stay running if you keep your foot on the Throttle?
After it reach's Operating Temp and the problem is gone what is the Idle Speed of the vehicle and does the Speed Increase or Decrease when the Cooling Fan comes on or the AC Compresor Engages.
Are there any Fault Codes Set?
