Can someone please verify the correct way these go. It was a mess when i got this car. The second pic is after figuring it out after more searching here. Does it look alright?
I am assuming this is an 85-87 Power Module, is that correct?
Thank you for your help. I am working on an '86 GLHT. FYI: This car has been upgraded with a '89 TII. I have the '87 GLHS logic module from FWD to make things work correctly. For some reason they cut wires in the harness and spliced them back together. They were trying to make the car run right using a MP computer for a '86 TI....the car actually "ran" like crap. I discovered that the distributor was not installed correctly, So was I was surprised that it would even start. Whoever put this together did a good job other than the distributor issue. The wires were in the right location on the LM for the AIS. It seems they were trying everything to make this car run right, not realizing they had the wrong LM for the swap.
