i have a nav and i need to check it. I have the plugs for the back. But when i power the red, orange to postive and the two grounds and the case ground to negative it lights up but nothing comes up on the screen.
What do you use for the buttons? Part numbers? Not trying to put you out of businessI repair these and sell them on eBay. On my test harness I have the black with white tracer (case ground), black with green tracer, and black with red tracer going to ground. I then have the solid red, solid orange, and solid white going to power. That should let you fully check it. If you can only get the date/time to display, then the buttons are bad. This is a common failure mode in the Navigators.
Chris
