hey folks,
just thought i'll let ya know that after some issues my T1 is up and running again
it has a new mpp hg, head bolts, self-ported ex manifold, new lines, new timing belt and all that cr4p
i haven't hooked up the airbox completely as of yet, i just connected the vac-lines so there are no leaks. and also i didn't connect the turbo to the intake, i wanted to see how it would run, kinda NA - lol :bash: also dont have any accessories hooked up, only belt is timing belt for now. it wasn't running longer than a minute so i figured i'll try without the water pump.
the timing belt seemed to be well enough aligned, might be one tooth on the cam after tdc#1, dunno exactely. i guess i prefer timing chains, lol.
compression wasn't too good, so i cranked it up yesterday night after sitting for about a year. it started right up after about 5 seconds of cranking but was running very rough on cyl 3 & 4. and yes, i did crank before that for some time without HEP to get some oil in the turbo
i checked everything and found out injectors 1 & 2 weren't working at all. so i took all inj out and cleaned them and replaced o-rings, now got a nice spray pattern as well
ok after that, i cranked up again and it was running pretty good on all 4 cyls. fired up at 2krpm and then went down to about 900rpm. vaccum was 18 according to the stock gauge, think that's how it's supposed to be right?
right now i hear that the valves are okay and turbo is spinning, but there is also one mechanical noise that is really disturbing. i also got a small deal of white smoke from the turbo, probably the firegum i used for swingvalve.
any thoughts what else i should check or anything to do before i start reving it and bring it finally back on the street, save for mounting accessory..!?
at this point i really want to express my gratitude to this great forum that brought me such a whole load of information and answers to all the questions i had :thumb:
thanks guys :drinking:
