Well actually I kinda, sorta, did in my first post.
Unless the heater wire is shorted to the signal line internally there should be no problem.
Connect your voltmeter to the signal line and watch the O2 crosscounts, if it is crossing above and below .450 volts it and the system are fine.
If the O2 heater got damaged from the short the O2 will not act as a HO2S and when exhaust flow slows the O2 will cool down and the vehicle will go into open loop.
That was the purpose of HO2S, to help with faster O2 warmup and stop constant in and out of closed loop operation.
On OBD2 (1996 and up) the system will set a fault for HO2S heater circuit open/shorted.
